I have a qubo wireless digital turbo. It was an newer upgraded model to replace a older faulty model.
Serial number is Q10076. Can I upgrade to use Zwift etc
Digital Qubo Wireless
Re: Digital Qubo Wireless
Zwift tells the trainer what the resistance should be at any given moment, you just have to keep those pedals spinning.
I agree, Windows 7 is upgradable to Windows 10 or Windows 11. However, it is important to note that Microsoft ended support for Windows 7 on January 14, 2020. This means that Microsoft will no longer provide security updates or technical support for Windows 7. As a result, it is no longer recommended to use Windows 7 on a production machine. If you are still using Windows 7, you should upgrade to a newer version of Windows as soon as possible.
Here are the steps on how to upgrade Windows 7 to Windows 10:
Download the Media Creation Tool from Microsoft's website.
Run the Media Creation Tool and select "Upgrade this PC now".
Follow the on-screen instructions to upgrade your computer to Windows 10.
Here are the steps on how to upgrade Windows 7 to Windows 11:
Make sure your computer meets the minimum requirements for Windows 11.
Download the Windows 11 installation assistant from Microsoft's website.
Run the installation assistant and follow the on-screen instructions to upgrade your computer to Windows 11.
I hope this helps! vidmateapp
