Qubo Digital Smart B+ (2014)with Zwift
marcin_tomaszewski
Postby marcin_tomaszewski » Sun Oct 29, 2017 11:32 am
Hi, how to connect Qubo Digital Smart B+ (2014 model) with Zwift desktop application on notebook?
The only sugestion I got is to purchase Elite Dongle ANT+ but it will work only with my IPhone not with notebook.
Thanks in advance.
Marcin
Re: Qubo Digital Smart B+ (2014)with Zwift
Postby Elite Admin S » Tue Oct 31, 2017 12:44 pm
If you want to connect via ant+, you'll need the dongle.
If your computer also supports the bluetooth smart communication, Zwift should also allow you to connect via bluetooth. Ask Zwift directly about this option
marcin_tomaszewski
Postby marcin_tomaszewski » Wed Nov 01, 2017 3:29 pm
I have USB ant+ dongle. My notebook sees it, Zwift sees it but Qubo Digital is not detected.
I've read on forum I need a firmware upgrade. S/N is Q 7797 and firmware is 56.
Marcin
Postby Elite Admin S » Fri Nov 03, 2017 11:38 am
So, you don't have a Qubo Digital Smart B+, but a Qubo Digital Wireless.
To use it with Zwift, you should upgrade it to have the fe-c protocol, but unfortunately your version is not the upgradable one :(
