Unable to connect head unit to Qubo digital
edwyn_mccann
I get the unit paired then it shows a message PARAM 205 Anyone any ideas?
Re: Unable to connect head unit to Qubo digital
Did you try with a complete reset of the console?
If not, follow these instructions:
-First power on the resistance unit.
-Push AC button (on the back of the handlebar console)
-Push and keep pushed together the right and left button until "EPP OK" appears.
-Push 1 time the central button - "AP2 OK" will appear .
-Push central button again 1 time - appears "Reset NO".
-Push 1 time left button - appears "Reset YES".
-Push 1 time central button then appears PAIRING.
-Push 1 time left button then --- flashing until it shows the number of pairing.
-Push the central button 1 time for HRate pairing
-Push and keep pushed the central button to show the initial screen.
If during the Pairing operation appears AP2 Err push AC button e try again.
If it doesn't work, please contact the customer care at this email address: myetraining@elite-it.com
