My trainer is making a very loudly noise when changing resistance, does anyone here have had the same issue?
I noticed some things, when it is calibrated with default values for P1, P2 and P3 the resistence changing happens but the trainer gets really heavyer and I can´t even peddle however if I change the values, the noise starts when I start climbing and it´s very annoying.
In contact with the Elite Support they told me that it´s a mechanical issue however my trainer is out of warranty and I can´t afford to buy a new one right now, so any help will be really appreciated.
Thanks in advance
Qubo Digital Smart B+ Making a loudly noise!
andrernascmento
Re: Qubo Digital Smart B+ Making a loudly noise!
It's due to a mechanical issue and unfortunately it's not repairable.
But we're analyzing your specific case with our commercial department to try to meet you half way, you'll receive a reply soon
