Qubo Digital Upgrade?
Re: Qubo Digital Upgrade?
Upgradable!
Hi Admins
My serial number is 58734 - is my unit firmware upgradable?
Kiff
Kiff
Hi kiff
Yes, it is upgradable.
For the complete procedure, contact the customer care at myetraining@elite-it.com
Can you tell me if I can up date the firmware on my trainer sn61104 fcc I’d o6r1695.
Can you tell me if I can the softwear upgrade on my Qubo please. S/n 61104. Also can you tell me the P1 P2 P3 figures it had from the factory please.
Your trainer is upgradable.
To have detailed instructions on how to do the upgrade and to have the original calibration values, please contact our customer care at myetraining@elite-it.com
Does any one know how long it is before you get a reply to your email about the update.
Is this qubo update? S/N Q 11932
yes, it is upgradable
Hi there,
S/N: Q6535 is upgradeable?
If yes, what does this upgrade mean from ZWIFT point of view?
Will be then this unit able control resistance in ZWIFT world automatically? Connected through ANT+?
Will be this unit also something like powermeter?
Thank you!
Brano
Thank you!
Brano
