did app eliminate ability to change p1 p2 p3
jefftober
Postby jefftober » Fri Nov 16, 2018 1:18 pm
I no longer see the options under "Advanced Configuration" to change p1 p2 p3 on the iphone app my e-training. on that page, just has "sensors" and "other", under which is just the version number - 3.9.1(227).
Am I missing something? Really need to change the numbers...
Re: did app eliminate ability to change p1 p2 p3
Postby Elite Admin S » Fri Nov 30, 2018 12:55 pm
That's quite strange.
Please select Parameters and scroll down til the end, the advanced configuration option must be there.
If you cannot see it, try uninstalling the app and install it again (it could be a visualization problem).
If the problem persists, contact our customer care at myetraining@elite-it.com
