Qubo Digital Smart B+
boban.radoicic
Postby boban.radoicic » Tue Nov 13, 2018 3:07 pm
Recently I have bought Qubo Digital Smart B+.
First thing that I have noticed is very strange noise which can be heard at the moment when trainer is connected to power source, it lasts for a few seconds and than stopped. Same noise is repeated during a training session from time to time?
I use Garmin Vector pedals as a power meter. During a training session on Qubo Digital Smart B+ I have noticed that power values that I read in Elite app, or ZWIFT (connected to the trainer) are significantly lower compering the values that I read from Garmin Vector pedals?
Please can you help me about these issues.
Thank you for your time.
Best regards,
Boban
Re: Qubo Digital Smart B+
Postby Elite Admin S » Fri Nov 16, 2018 12:54 pm
The noise could be the sound of the motor that adjusts the trainer resistance.
But if it is something very loud and annoying, please send a video in which we can hear the noise at myetraining@elite-it.com
About the power, if you notice a difference with your power sensor I suggest you to do a calibration (advanced settings in the app).
Follow the instructions there.
