My trainer is Q1895.
Am I right in guessing that this is not upgradeable?
At what serial number did it become possible to upgrade?
Digital Qubo Wireless
Re: Digital Qubo Wireless
I confirm it is not upgradable.
Qubo Digital are upgradable from serial number 9784.
Hello!
Can you tell if I can upgrade my qubo digital wireless serial Q 11191.
I have pairing problems, the value of parameter is on 0270, it's that right? What can I do? The roller don't pairing with my app...
Please help!
Please help!
Hi Fiter13,
I confirm you that your trainer is upgradable. If you want to upgrade it, contact our customer care at myetraining@elite-it.com.
The upgrade will allow you to connect it to any application that is ant+ fe-c compatible (and of course your device must support the ant+ protocol).
The value you've seen (0270) is ok.
You should be able to pair it with the app, but only if your device supports the ant+.
About the console, try doing the pairing again from the menu after doing a reset by pressing the AC button on the back of the console (check the user manual for the various steps).
Hello, my qubo trainer´s serial number is 12295, is it upgradable? Thanks.
neal.lyons
Sorry for jumping onto these threads late but is the Elite Qubo Trainer S/N 12567 firmware upgradeable?
Thankyou
Thankyou
@jmosso
@neal.lyons
Your trainers are upgradable.
To have the complete procedure, write to the customer care at myetraining@elite-it.com or real@elite-it.com
@neal.lyons
marco.schleicher
My SN is Q 12154 - is it upradeable?
marco.schleicher
nnikolopou
SN: Q 11932. Is this upgratable?
