I have an Elite Turbo Ditigal Qubo Wireless, can I update the firmware on it?
Digital Qubo Wireless
Re: Digital Qubo Wireless
Can you tell me the serial number of your trainer, so I can check the firmware version?
Usually, the upgradable trainers have a "firmware upgradable" sticker, but the serial number is a safer way to check it.
The serial number is SNQ11779.
I confirm you that your trainer firmware is upgradable.
I've forwarded your request and in few hours you should receive an email with all the instructions to do the upgrade.
Please remember that:
- to do the upgrade, you'll need a pc and an ant+ dongle
- after the upgrade, you won't be able to use the handlebar console anymore
vincent.golle
My trainer's S/N is Q13936, is it updateable ?
vincent.golle
Is my trainer upgradeable ? SN Q13936
Hi Vincent
I confirm you that it is upgradable.
To have the complete procedure write to our customer care at real@elite-it.com and ask for it (specify the serial number in the email)
Hey,
Same question , serial number is SN: Q 09620
@okoktao
I'm sorry, your version is not upgradable.
I have just recently found this possibility. Is SN: Q 0340 upgradable?
Many thanks
Peter
Many thanks
Peter
Users browsing this forum: No registered users and 45 guests
