I have a Qubo Digital Smart B + on my new E Motion rollers. I have managed to get connected via Bluetooth on my iPad and iPhone and all is good except the cadence values are way over the real values. for example my last training they came in 182 average and 525 max
Speed, Distance, Power and HR are all within normal ranges.
Any ideas or suggestions would be appreciated.
Cadence Issue
Re: Cadence Issue
The sensorless cadence algorithm works well in standard situation (smooth pedaling, chain well tensed, not too much high cadence...) but in some situation the value may be not accurate.
If you need a precise cadence value you have to use a real sensor.
You can use our wired sensor, which is really cheap (https://www.shopelite-it.com/en/spare-p ... sensor-kit) or you can use a wireless cadence sensor (ant+ or bluetooth smart, depending on the device you are using with the trainer)
