Drivo with Sram Eagle and Boost 148
Mibra
Postby Mibra » Thu Nov 09, 2017 6:12 pm
I will buy a new MTB Hardtail with Boost 12x148 and Sram Eagle. Will it work with the drivo? THANK You
udokoeken
Re: Drivo with Sram Eagle and Boost 148
Postby udokoeken » Mon Nov 13, 2017 1:16 pm
Good question. My MTB is also boost.
Postby Elite Admin S » Thu Nov 23, 2017 10:33 am
Please send an email to the customer care at real@elite-it.com with all the characteristic of the bike
dave
Postby dave » Sat Feb 15, 2020 4:42 pm
Hi, I don't know how you got on with this for your Drivo I/II but i've just tried fitting a SRAM Eagle NX1230 cassette to my Kura and although the Shimano freebody is compatible with this particular cassette, the size of the 50t top cog means that it fouls on the plastic body of the trainer and will not turn.
I suspect that the Drivo i/II is of a similar design to the Kura but the newer trainers like the Direto X and Suito won't have this limitation.
There is a 12mm boost 148mm adapter available BTW.
slejdo
Postby slejdo » Sat Feb 15, 2020 5:59 pm
Yes, you need Elite Thru-Axle Adapter for Direct-Drive-Trainer Boost. And definetly, you can use Drivo in ERG mode (no changing gear). If you want to change gear (no ERG mode) maybe there will be problem with space (Drivo cover and rear derauiler cage)
Tested on my Drivo, PG-1230 EAGLE cassette, mech. Eagle XX1 12spd derauiller with Ceramicspeed cage.
So - for me ONLY ERG mode !
Return to “Drivo & Drivo II”
