I’ve tried looking for an answer but haven’t found a good one ... so can anyone share what “uniformity” under the pedal analytics actually means?
Thanks! Jon
Uniformity?
Re: Uniformity?
The uniformity index is the ratio in percent between the average power and the max power outputs of the pedaling stroke.
It is impossible to reach a 100% uniformity: a value close to 65% is considered very good.
The higher the value, the better the efficiency.
Basically, if you reach a 100% value it means that you're applying the max power in the space of the entire pedaling circle.
jon.dunsdon
Re: Uniformity?
Thanks for the explanation.
It would be great to be able to see this, and the left right balance, in other applications or on a garmin device - I use Xert and Zwift to train and it’s a shame to not even to able to record in a different device, as it’s such a useful thing to understand.
