Drivo calibration ?
619459
Re: Drivo calibration ?
Postby 619459 » Mon Feb 12, 2018 4:27 am
I'm trying to do this calibration and it keeps failing to calibrate. What else can I try to get it to recalibrate?
Postby Elite Admin S » Fri Feb 16, 2018 11:53 am
Please contact the customer care at real@elite-it.com specifying the serial number of the trainer and explicating the situation
stutsmall
Postby stutsmall » Fri Nov 09, 2018 3:11 am
jbroussia wrote:PS: what is that number in circumference ??? I set mine to 2160 mm, why does it show 629,74 ??? (it's not the value in feet/inches, not the diameter, ... ?)
Hi jbroussia - I noted comment and provide a quote from a cycle training program called Perf Pro that we have to use for triathlon training - NB do not think about using Per Pro - its fiddly compared to more modern programs such as Zwift, Trainer Road, Road Grand Tours etc etc - it is a more specialist coach provided program.
[i][i][i]Also, note specific trainers like Elite have some very unique Wheel Circumfrences that need to be set. For example, the Elite Direto requires a 173mm WC and the Elite Drivo requires a 630mm WC.[/i][/i][/i]
I do not use the Elite software much, however as a test resolving issues, I have had some tests and my speed gets as high as 80 klm per hour when it should be about 25, and I am certain it has something to do with the above comment.
ericp
Postby ericp » Sun Dec 16, 2018 12:37 pm
Dear all,
The calibration video doesn't launch when trying to calibrate via the App on my desktop computer. I warm up 10 minutes, click it, it is asking me to pedal but that's it, it freezes there. No video, no calibration, no stop pedalling message etc.
Growing a bit tired of this and considering returning the Drivo 2 which is a shame as I haven't really used it yet but the power output is way too low from perceived effort (on Trainer Road) and needs calibration.
Please help, anyone?
Kind regards,
Eric
tit_babinski
Postby tit_babinski » Mon Jan 14, 2019 11:25 pm
Hi !
Just got a Drivo 2.
Wanted to do a calibration. It says "increase speed". I push really hard, even on the 50-12, and it keeps saying "increase speed" until it fails.
DO you have any idea what it could be ?
tit_babinski
Postby tit_babinski » Tue Jan 15, 2019 10:09 am
Hi !
I'm trying to calibrate my Drivo 2 using the Windows desktop app. It keeps telling le to "increase the speed" until it fails. And I can telle you, I'm pushing really hard on those pedals but I just can't succeed in calibrate it.
Katherine792
Postby Katherine792 » Tue Jan 29, 2019 5:49 am
I have a different problem (with direto though but I understand that the process and the app is tha same). The problem is that I don't even have an option for calibration in my e-training app (android). Any one had the same? Plus there is no windows app for direto trainer.
Return to “Drivo & Drivo II”
