Anyone have an idea what this sound is?
gawa62
Postby gawa62 » Thu Oct 31, 2019 6:29 pm
Purchased the Drivo last week brand new from Halfords.After do an FTP test on Trainerroad I heard this noise.
https://youtu.be/dedq4mGVvu4
Hopefully it's a simple fix and the cassette is brand new and on correctly.
Gary
edwinf8936
Re: Anyone have an idea what this sound is?
Postby edwinf8936 » Thu Oct 31, 2019 10:16 pm
First thing I would do is take it back off and reattach it and make sure it is set in the drops correctly AND that you have the quick release properly tightened. With these trainer skewers, they tighten a little different than normal.
gawa62
Postby gawa62 » Thu Oct 31, 2019 11:01 pm
Thanks, I've done that numerous of times and even changed different skewers.
Return to “Drivo & Drivo II”
