Drivo squeaking under power transitions
dnservis@otenet.gr
Postby dnservis@otenet.gr » Fri Dec 28, 2018 3:17 pm
My DRIVO recently, produces an irregular squeak, under power transitions, in the first 15' or at the end of the sessions when low power is applied. It is intermittent, so often nothing is heard! Sounds like something needs lube, or so...The trainer has nearly 4000km, it is operated under dry conditions and it is kept in the appartment. So far I had only greased a bit its' right side belt. Has anybody encountered similar noises?
dnservis@otenet.gr
Re: Drivo squeaking under power transitions
Postby dnservis@otenet.gr » Tue Jan 08, 2019 2:34 pm
Here is the noise and general behavior
[https://youtu.be/LOJEPyMYdB4]
mgfjd
Postby mgfjd » Sat Jan 26, 2019 5:26 am
Delete this post. I found the issue.. Unrelated to the thread.
Return to “Drivo & Drivo II”
