Thru Axle Compatibility
sonikboy
Postby sonikboy » Mon Oct 29, 2018 6:28 pm
Hello,my Ridley X-trail has a thru axle of 167mm - is there an adapter available for this please to use with the Drivo?
Re: Thru Axle Compatibility
Postby Elite Admin S » Wed Nov 14, 2018 2:09 pm
Usually thru axle are 142 or 148mm.
Are you sure of your measure?
drsword
Postby drsword » Fri Nov 16, 2018 4:25 pm
I have a Cannondale Synapsewith a 160 x 12 mm axle. Also wondering if this will work with the Drivo
sonikboy
Postby sonikboy » Thu Nov 22, 2018 5:31 pm
Thankyou for your reply,
I can confirm that my thru axle has 167mm x 12 written on it,however it appears to fit perfectly well using the supplied adapter,with no apparent or obvious problems.
I can only deduce that its effective working length is compatible with the Drivo's dimensions and that 167mm is it's overall length?
crabtree7@me.com
Postby crabtree7@me.com » Sun Dec 02, 2018 6:09 pm
I've just bought a novo smart but my bike has a thru axle which won't fit the turbo. Where can I get a adaptor
richshall@gmail.com
Postby richshall@gmail.com » Tue May 21, 2019 12:43 am
I have an Elite Drivo and recently got a bike with a 12mm thru axle. The adapters work fine and the frame fits onto the trainer but the actual axle will not fit through the trainer. It goes in about 2 inches from the non drive side but thats it. anyone else have this issue or know how to fix it?
Return to “Drivo & Drivo II”
