Drivo I annoying behaviour
Posted: Wed Oct 03, 2018 8:11 pm
by Jörg Hofmeister
Hi everybody,
I have a problem with my Drivo I. When using Zwift and it goes uphill (1% slope or more), it feels like little strokes or blows are going through the unit. I can hear it and also feel it going through my bike. It is almost absent at 0% or downhill. Obviously, it has something to do with the software adjusting the resistance of the trainer. The problem does not show when just pedaling without any software controlling it.
It was ok for some time but now it is even worse and really annoying. Otherwise, the functionality is ok. Any ideas anyone? Maybe the belt is too tight or too loose?
Thanks,
Jörg
Re: Drivo I annoying behaviour
Posted: Mon Oct 08, 2018 9:27 am
by Elite Admin S
If you use my e-training in the same conditions, do you have the same behavior?
Posted: Mon Oct 08, 2018 9:37 pm
by Jörg Hofmeister
Thanks for your reply. Yes, it also happens with the e-training app.
Posted: Tue Oct 09, 2018 8:24 am
by Elite Admin S
When the slope/power changes, the internal motor moves to adjust the resistance.
It is not very noisy, usually the noise of the chain is higher than the sound of the motor.
But if you think that the sound is too loud and you also noticed an increase of the noise, please contact the customer care at myetraining@elite-it.com adding a short video or recording of the noise. The guys there will tell you what to do.
Posted: Tue Apr 02, 2019 5:57 am
by jojo213
Thanks for INFO.
