Thru Axle on Drivo
Thru Axle on Drivo
Hi all! I just ordered a Rose Xeon 3100 Disc Di2. The bike have rear thru axle of 10 mm x 135 mm. Is my Elite Drivo compatible? Do I need to buy an adaptor? Thanks a lot in advance for the help.
Re: Thru Axle on Drivo
Hi!
I confirm you that your bike is compatible with Drivo (Drivo is compatible with axles up to 142mm).
You have to use the specific adaptor included in the package.
Thanks for the help, but still in doubt. If my bike is 135 mm it won't be enough width to properly assembly it as it need 142mm width? It wont have enough space as it has 7 mm less width??????
I'm sorry, I've asked again to our mechanics and there has been a misunderstanding on the width.
The adaptor for thru axle bikes is not compatible with your 135mm axle bike. Sorry but it is not possible to use it on our trainer.
