I can no longer set the power smoothing value on my Drivo. I have attempted connection with MyETraining via bluetooth/iPhone and ANT+/PC with the same result that I get a spinning circle and a failure message that this operation failed due to an internal error. Please advise.
Cannot set power smoothing Drivo
Allez Prosser-Snelling
Re: Cannot set power smoothing Drivo
Did you try using a different device to change the power smoothing?
Do you have the same issue?
