Training Test on Direto - negative numbers
Posted: Tue Aug 14, 2018 10:09 am
Hi all, just bought a Direto, after a few tests to make sure data is recording I ran the 'Training Test'.
I stopped the test under a minute into the last 10 mins, I could not hold my target HR as the room was too hot and blew up.
The power graph and HR map perfectly to the data I was seeing on the app, but when you look at the numerical test results it shows very low and negative numbers. Even stopping the test early I cannot see why this would happen.
Images of result attached below.
I was also slightly surprised at 182 BPM HR being hit at 240watts. I am just coming back from an injury however so this could be my lack of fitness at the moment. Previous sub-max ramp tests I have gone over 300watts without blowing in the same way. I reserve judgement on the power being out until have run some more tests and recovered some fitness - so long as it is consistent it works for me as a training tool.
