I recently changed the wheel circumference to 173mm as recommended in the manual for the Direto - to correct speed readings on Garmin/Wahoo head units.
The next time I used Zwift resistance dropped to zero/nothing every 3-4 mins - each time lasting around 10 seconds. It took me a while to realize that the wheel circumference change had caused this, I was ready to return the Direto until i found this post on the Zwift support forum:
https://support.zwift.com/hc/en-us/comm ... 5001505091
Changing the wheel circumference back to AUTO (2070) on the Wahoo head unit fixed it, not sure why as I don't use the head unit when running Zwift - does it change something in the trainer itself?
It seems i'm not the only Direto owner who has encountered this bug, can we have it fixed please?
Thanks,
Clive
Direto resistance drops in Zwift every 3-4 mins
