Probleme de vitesse
laurent@jullian.eu
Contact:
Probleme de vitesse
Postby laurent@jullian.eu » Tue Jan 09, 2018 7:27 am
Bonjour.
Je viens de faire l'achat d'un Direto et lorsque je le connecte avec mon Garmin Edge 1030, la vitesse annoncée sur le GPS Edge 1030 est complètement erronée, j'ai une vitesse de 150/190 km/h en pédalant tranquillement. Y'a t'il une technique particulière pour connecter ces équipement ensemble ? Merci d'avance.
Hello.
I just bought a Direto and when I connect it with my Garmin Edge 1030, the speed announced on the Edge 1030 GPS is completely wrong, I have a speed of 150/190 km / h pedaling quietly. Is there a special technique for connecting this equipment together? Thank you in advance.
Re: Probleme de vitesse
Postby Elite Admin S » Fri Jan 26, 2018 11:12 am
When you use a non Elite device or app, you have to set a circumference that consider also the internal ratio of Direto.
So, in your Garmin settings you have to set a circumference equal to your wheel circumference divided by 12.1
ggwen1979
Postby ggwen1979 » Fri Jan 14, 2022 1:10 pm
Dear support office,
I have the same problem with the speed indication on my garmin watch or edge with the wheel circonferential mesure recorded 2105 mm.
Which is the ratio (devide 2105 / by ?) for the suito elite device ?
Best regards.
Users browsing this forum: No registered users and 46 guests
