Direto and golden cheetah
kreto
Postby kreto » Sat Jan 06, 2018 7:12 pm
have any one got direto to work total on golden cheetah(ant+ and/or BT) for me only problem is speed value is off(wrong to high athlete wheelsize 173)
i you got it working som hints please :) thanks
vw67split
Re: Direto and golden cheetah
Postby vw67split » Sat Jan 20, 2018 4:16 pm
I'm trying to get mybdireto working in Golden Cheetah, but in ERG mode, the resistance does not change.
I've added the different sensors, can see speed, power, ... but power is not adapted according to the program.
Any idea what I'm doing wrong?
kreto
Postby kreto » Thu Jan 25, 2018 9:53 pm
hi
on mine BT worke fine but ant did not control power until i added trainer nr xxxx,f (if remember right) you need 3 letters s=speed/cad p=powermeter and f=resistens control (if remember right) in trainer tab settings
let me know if you get speed to be the right value
