Direto ERG Mode and resistance
Posted: Wed Dec 13, 2017 5:14 am
I have the Direto and have been riding mainly on Zwift. I have noticed that ERG mode doesn't match up with the power I am putting through. For example, if I am doing a block that is 100 watts, I can be pedalling at a constant cadence and the power I get back goes all over the place and is very spiky. I tried to test it using the etraining app on PC to set certain power levels and the graph I get back is also very spiky and doesn't look consistent.
I am connected to PC using Ant+ on an extension cable so the sensor is right by the trainer.
Is there a setting I am missing?
