Resistance Issue with Elite Direto XRT and Garmin Forerunner 955 When Using Humango App
Posted: Fri Feb 07, 2025 8:41 am
by celik.ozuduru
I have been using the Elite Direto XRT indoor interactive trainer and training with the Humango app. All scheduled workouts are automatically uploaded to my Garmin Forerunner 955 watch. Initially, I had no issues completing my bike sessions with my watch connected to the trainer. However, recently, as soon as I launch a scheduled training session from my watch, the resistance immediately maxes out, making it impossible to pedal. If I manually adjust the resistance and/or gradient from my watch, it disrupts the structured workout. Interestingly, when I launch a Garmin-generated bike training, everything works fine. Does anyone know what might be causing this issue?
Note: Both my Forerunner 955 and Elite Direto XRT firmware are up to date.
Re: Resistance Issue with Elite Direto XRT and Garmin Forerunner 955 When Using Humango App
Posted: Fri Feb 07, 2025 5:30 pm
by 3willy_it
Hi there, same trainer, same watch and same problems...I changed something inside the MyEtraining app, and now, when I'm in a workout, the trainer randomly disconnects from my Garmin, lowering the resistance to 0. After 20 or 30 seconds, it restarts working correctly... Any ideas?
Posted: Wed Feb 12, 2025 11:51 am
by celik.ozuduru
That issue also happened last week, in the middle of the training session, resistance suddenly dropped along with the power. it is really annoying since that I have been trying to fix this issue for a long time.
Posted: Thu Aug 28, 2025 7:05 am
by florencepugh
You should disable "use trainer control" on the watch and let Humango push the workout directly to the Direto XRT
Pips NYT, or re-export the workout in a Garmin-compatible format to avoid the max resistance spike.
