no power, no speed, nothing
Posted: Mon Jan 22, 2024 7:45 pm
by aurelienpirot
I had a problem during my session with a cassette noise, my cassette was no longer tight.
I tightened it but since then I have no more speed, no power.
it spins in the void
something broke?
what should I check?
thanks
Re: no power, no speed, nothing
Posted: Tue Jan 23, 2024 10:14 am
by steve.hammatt
When you turn the pedals by hand, do you see the flywheel move? It sounds like perhaps the freehub has broken.
Posted: Tue Jan 23, 2024 10:27 am
by aurelienpirot
hello,
I will test it tonigth
it's easy to repair it?
Posted: Wed Jan 24, 2024 4:13 am
by eightmann
Have the same problem not power reading, no speed, not able to calibrate from the app. Running the v80 firmware. Flywheel turns fine as expected.
Posted: Wed Jan 24, 2024 10:36 am
by aurelienpirot
hello
it's the belt. she is broken
where can i find it?
Posted: Thu Jan 25, 2024 9:58 am
by steve.hammatt
aurelienpirot wrote:hello
https://www.shopelite-it.com/en/spare-p ... ometrainer
