I had a problem during my session with a cassette noise, my cassette was no longer tight.
I tightened it but since then I have no more speed, no power.
it spins in the void
something broke?
what should I check?
thanks
no power, no speed, nothing
Re: no power, no speed, nothing
When you turn the pedals by hand, do you see the flywheel move? It sounds like perhaps the freehub has broken.
hello,
I will test it tonigth
it's easy to repair it?
Have the same problem not power reading, no speed, not able to calibrate from the app. Running the v80 firmware. Flywheel turns fine as expected.
hello
it's the belt. she is broken
where can i find it?
aurelienpirot wrote:hello
https://www.shopelite-it.com/en/spare-p ... ometrainer
Users browsing this forum: No registered users and 45 guests
