Hi all
On my last Zwift-session I had some problems activating ERG mode.
The trainer made a strange noise, see video here: https://www.dropbox.com/s/om7wjkqbe5eke ... e.MOV?dl=0
With disabled ERG-mode shifting and resistance was kind of ok, lower gear -> less watts and higher gear -> higher watts and no strange noise even though I could not adjust resistance.
Any thoughts on what can be done? Parts in need of service or replacement?
BR
//Jens
Elite Direto Zwift ERG mode malfunction
Re: Elite Direto Zwift ERG mode malfunction
In the case anyone runs into the same problem....
My problem was solved by Elite support by performing the following:
1. Do the "Resistance Check On Interactive Trainers": https://elitesrl.zendesk.com/hc/en-us/a ... e-Trainers
2. - From My E-Training app go to Workouts -> Level Mode (it is a free function so you don't need an active annual subscription)
3. Click on Start and change the level progressively to 16 and now power off the trainer.
- clean accurately the golden endless screw that comes out from the stepper motor (silver cylinder) with a rag
- grease again the golden screw with vaseline grease or a grease for a small mechanical part
- at the end power on the trainer and spread a bit the new grease changing the level
Elite support is really "elite"!
//J
//J
