Calibrge
Posted: Fri Oct 01, 2021 12:05 pm
by Bibi58
Hello,j have a recent direto xr t,, and when I do the calibration with myetraining the value written on the labeled is 6601 and the test gives me 6600, it needs a setting or I can leave like that thank you for your answer
Re: Calibrge
Posted: Fri Oct 01, 2021 12:46 pm
by Elite Admin S
It is ok!
Re: Calibrge
Posted: Fri Oct 01, 2021 2:10 pm
by Bibi58
Hello and thank you for your answer, so it’s good I can leave it like that, from how many mistakes to fix.
Re: Calibrge
Posted: Sat Oct 02, 2021 6:36 am
by Bibi58
Hello, I misspoke, how much margin of error is this acceptable thank you
Re: Calibrge
Posted: Tue Oct 05, 2021 8:46 am
by Elite Admin S
If the difference is more than 5 points AND at the same time you have any issue (like slipping, strange noises or a sudden drop in power), then it may be necessary to tighten the belt. In this case, contact our customer care to have the detailed instructions on how to do it.
If there's no associated issue, you can use the trainer even with an higher difference in the offset value.
Re: Calibrge
Posted: Tue Oct 05, 2021 4:27 pm
by Bibi58
Thank you
