Hey guys,
last week I bought a new direto XR. After finished my first ride I did a calibration in the elite mytrainer app, the value i got was 6534, but on the bottom of the trainer it reads 6536. The ride the day after i felt my power numbers were a bit low. Do i need to tighten any bolts or is the value still exceptable? Greets
New Direto XR calibration value is off!
Re: New Direto XR calibration value is off!
The power numbers reported take into account the offset value acquired during calibration. If the belt isn't slipping, you should be fine. I've ridden for a few years (with the original Direto) with my calibration number -4 from the number on the bottom of the trainer. Power values are within 2 - 5 watts of my Garmin Vector 3 dual sided power meter (e.g. < 1% difference).
Hey simon,
thanks for your nice answer. Then I will leave things as they are. Greets Flo
