Direto X resistance changes
Posted: Wed May 05, 2021 5:18 pm
by winlikefin
I bought a Direto X for my son in December 2020.
He was never really happy with it but used it during lockdown for training using Zwift and downloaded sessions on his Garmin 520.
I need to get fit and have started using it myself this week for 20-30 minutes at a time.
I have noticed that the resistance increases for a few seconds then goes back to normal.
I am not using Zwift - just recording my time on the bike using the Wahoo app.
Strangely the resistance change doesn't happen in the 2 easiest gears but does in any of the other nine.
I have calibrated the trainer and there are no firmware updates required.
Am I the only one to have this problem?
thanks
Finbar
Re: Direto X resistance changes
Posted: Thu May 06, 2021 8:59 am
by Elite Admin S
Did you notice in which occasion the resistance increases without reason?
Does it happens only at start up or during the training session?
If you use my e-training (just for a test) do you have the same issue?
Posted: Thu May 06, 2021 10:47 am
by winlikefin
I haven't used the myEtraining app to record any sessions.
I will try it later today.
My training is 'free' - I don't connect to Zwift (or any of the other platforms), or follow any program with set power levels, I just sit on the bike and try to get my heart rate up by turning the pedals.
The resistance seems to change at a regular interval - it seems like every couple of minutes the resistance increases for a few seconds then returns to normal.
It happens all through the session - if I use the 2 easiest gears then it doesn't happen but any of the other gears cause it to happen, doesn't matter if I pedal fast or slowly.
I'll try to time it when I'm on later.
thanks for the reply
Finbar
Posted: Thu May 06, 2021 11:19 am
by Elite Admin S
Now I got it!
You are pedaling but you're connected with your Wahoo. If the resistance sent by the wahoo device is 0 (minimum resistance), every 3 minutes the trainer does a homing procedure (basically, it checks to not have loose the zero position). This is what you're experiencing.
8-)
Posted: Thu May 06, 2021 12:22 pm
by winlikefin
That's good to know!
Is there a way around this or do I just have to put up with it?
Is it an issue with the Wahoo or would other apps/devices have the same thing?
Finbar
Posted: Fri May 07, 2021 8:17 am
by Elite Admin S
It's not an issue, it's a functionality of our firmware. It is used to check the zero position of the motor and it happens when you're connected with an application or a device and resistance is zero.
I understand that this may be unpleasant for your type of training though.
You have different options:
- you can connect the trainer on your wahoo as a speed&cadence sensor (and not as an indoor trainer)
- you can power off your Wahoo device (but in this case you won't see your speed... I don't know if you are interested on it).
Posted: Thu May 13, 2021 9:33 am
by winlikefin
I have tried the turbo again using different apps (Zwift & RGT Rouvy) and a different head unit - Garmin 520.
Every time the same thing happens.
The resistance is 'normal' for about a minute then it gets really hard for 10-15 seconds before going back to normal again.
This repeats every minute or so - it doesn't sound like the 3 minute firmware check that you describe.
My son tells me that the turbo has always done this and this is the reason he doesn't like the turbo - he preferred using the old Turbomuin that had worn out bearings! I have recently changed the bearings in the Turbomuin so will be going back to using it.
At the minute the Direto-X is unusable for any training.
Posted: Thu May 13, 2021 9:54 am
by Elite Admin S
Please do this test:
- power off ALL your apps and devices
- power on ONLY one of them (for example, only your Garmin)
- connect the garmin to your trainer as a speed&cadence sensor plus a power sensor (and NOT as an interactive trainer)
- start riding
If also in this way you have resistance variations, please contact our customer care.
Go to this page, select the product and then the link to open a ticket:
https://support.elite-it.com/
Posted: Fri May 14, 2021 11:09 am
by winlikefin
I did test the turbo connected to Zwift as a power source and cadence source.
The resistance changes still happened.
I disconnected the laptop & unplugged the turbo to be sure all connections were cancelled then connected to the myETraining app on my phone.
The turbo connected right away and I was able to see all the information displayed on screen.
When I tried to adjust the resistance of the turbo using the app I did not feel any difference at the crank but the power displayed on the app increased dramatically - up to 1850 watts!
As the turbo is only a few months old I contacted the retailer and they have agreed to replace the turbo with another one.
I have left the faulty one with them and am waiting for the replacement to be delivered to the store.
Many thanks for your advice on this.
Finbar
