Brand new Direto vibrating
gnorp
Postby gnorp » Wed Jan 16, 2019 1:18 pm
Der Elite Support,
Just started set up of my brand new Direto. Unfortunately the device causes vibrations when pedaling at increased speed. The vibrations/shaking are quite strong and noticeable on the whole floor/house even with a damping mat applied. Frequency is low and similar to something mechanically not running “round”. I did not manage to record the vibrations due to the low frequency. The vibrations occur when the device is switched of as well as in on mode. Changing the resistance also did not change the effect.
Is that something I can fix on my own?
Thanks in advance & best regards
Dolllups@yopmail.com
Re: Brand new Direto vibrating
Postby Dolllups@yopmail.com » Fri Aug 16, 2019 9:46 am
With the passage of time there are improvements in the technology and same goes with this. However there is assignment writing that can help the people in knowing the different shades of things.
Return to “Direto”
