Speed off when using Wahoo head units
Posted: Sat Dec 29, 2018 12:30 am
by cmk
I am using my Direto (which I love) with two Wahoo head units (Elemnt and Bolt). I have read online that to adjust the speed... the wheel circumference needs to be adjusted to .173. That said, does anyone know where that change needs to be made? I can't figure that out... Help.
Re: Speed off when using Wahoo head units
Posted: Fri Feb 15, 2019 12:06 am
by curtcorey
In the Wahoo Fitness app (not the Wahoo ELEMNT app) select Sensors on the bottom bar. There you can add a new sensor or configure one already added.
Posted: Thu Feb 28, 2019 9:07 am
by Marcobaggioli@me.com
Non funziona nemmeno cosi’... non e’chiaro come aggiornare il diametro sulla app wahoo fitness possa quindi anche aggiornare l’ELMNT....
