Morning
I am looking at swapping my cassette on the Direto XR as it is wearing now having done about 5000km and causing the chain to slip. Do I have to use the special tools to remove it (https://www.shopelite-it.com/en/sensors ... eto-xr-kit) or is there an alternative toolset I can get hold of to change the cassette out?
Many thanks in advance.
Swapping cassette on Direto XR
Re: Swapping cassette on Direto XR
You need a wrench to remove the adapter that blocks the freehub but this operation may damage the adapter itself.
Our is specifically made to do this operation without damaging the adapter.
You need also a whip wrench to remove the cassette from the freehub
rwgladwin@gmail.com
Thanks - sounds like I need to purchase the tool then.
Is it only available from your Italy store as the delivery charge is quite substantial bearing in mind the cost of the tool!
Many thanks
Many thanks
If you have an agreed courier you can contact us through shopelite web site and we can arrange the delivery
