Calibrge
Re: Calibrge
Hello and thank you for your answer, so it’s good I can leave it like that, from how many mistakes to fix.
Re: Calibrge
Hello, I misspoke, how much margin of error is this acceptable thank you
Re: Calibrge
If the difference is more than 5 points AND at the same time you have any issue (like slipping, strange noises or a sudden drop in power), then it may be necessary to tighten the belt. In this case, contact our customer care to have the detailed instructions on how to do it.
If there's no associated issue, you can use the trainer even with an higher difference in the offset value.
