Direto Power Sensor
tobyfifield
Direto Power Sensor
Postby tobyfifield » Thu Oct 19, 2017 10:09 pm
Hello, I'm hoping someone can help. When configuring my Direto time should I select both cadence and power on the menu option (see attachment). When I do select both, it picks up the cadence sensor fine but cannot find the power sensor (see attachment).
Am I doing something wrong here?
Re: Direto Power Sensor
Postby Elite Admin S » Fri Oct 20, 2017 10:13 am
You have to select them only if you want to use external cadence or power sensors.
Otherwise, you have to leave them on "no" (the app will then receive the power and cadence value from Direto)
tobyfifield
Postby tobyfifield » Fri Oct 20, 2017 1:36 pm
Can you advise why the system is picking up a cadence sensor then when I don't have anything external running/attached?
Russi
Postby Russi » Fri Oct 20, 2017 5:20 pm
I am contemplating buying a Direto since I have a problem with my Tacx:
whilst doing interals and changing from 100 watts in recess up to 400 watts during intervals the trainer jumps from one second to the next 300 watts up which is impossible to pedal
thus I have to programm 5 sec increments at 20 watts from one level to the next which is a nuissance
Do the Elite trainers have a smooth transition or can I programm a smooth curve on the training app??
Thanks for feedback
Marc
Postby Elite Admin S » Tue Oct 24, 2017 11:28 am
Direto has an internal motor that adjusts the resistance, so the change is always gradual.
Users browsing this forum: No registered users and 76 guests
