Band New Direto X not working. Freehub - rachet problem
rafael16
Postby rafael16 » Tue Apr 21, 2020 11:38 pm
Hello
For good (or bad) I just upgraded my trainer from an Elite Digital Smart B+ to an Elite Directo X. Unfortunately the new one is not working, local distributor has no other units to replace it, and there are no smart trainers on the market.
The problem started with a knocking noise and after some kilometers pedaling started to fail. Each time I put power on the pedals, a hard noise is heard and no pedal traction is observed.
You can see the problem when pedaling here
https://vimeo.com/410372990
and the knocking noise in the freehub here
https://vimeo.com/410372945
Please, any advise while Elite gives me support (if they do) is welcome
Best Regards
Rafael
Johny32
Re: Band New Direto X not working. Freehub - rachet problem
Postby Johny32 » Wed Apr 22, 2020 12:28 am
Hi there,
The second video doesnt work.
In the first video, the noise, appears to be from the cassete itself. Where you changing gears?
It seems to bee the chain pumping from the cassette tooth.
Im not an expert at all in trainers. Just a owner of a Elite Direto. :)
rafael16
Postby rafael16 » Thu Apr 23, 2020 2:14 am
Thank you Johnny
The first video shows the actual problem
It is working now
Rafael
Johny32
Postby Johny32 » Thu Apr 23, 2020 9:10 pm
Thats really good news.
Regarding the knocking noise, just check the inside, only to be sure about it, check the inside to confirm the state and the position of the belt.
Best regards
Postby Elite Admin S » Mon Apr 27, 2020 5:32 pm
If you have strange noises on the trainer, contact our customer care at myetraining@elite-it.com.
Sometime it's only necessary to do some little adjustments, sometimes it may be necessary to replace some parts.
white.sara
Postby white.sara » Wed May 06, 2020 5:38 pm
Were you able to figure out what's causing this noise? My Direto X is also making an extremely similar noise.
rafael16
Postby rafael16 » Sun May 31, 2020 2:53 am
Finally Elite support changed the rachet.
After installing it, all the problems were gone.
Now enjoying the trainer
Thank you Andrea
rafael
mvseeters
Postby mvseeters » Tue Jan 19, 2021 12:59 pm
I have exactly the same problem and have sent an email to Elite.
After 4 weeks still no response.
Tried to obtain a new freehub at the dealer or at all the known webshops, but no succes sofar.
I am very annoyed that Elite does not react at all.
Users browsing this forum: No registered users and 41 guests
