Direto calibration
fuego.bluedane
Re: Direto calibration
Postby fuego.bluedane » Fri Sep 20, 2019 8:32 pm
elite wrote:Isn't Ok. Max difference is 5 points. You should do calibration https://www.youtube.com/watch?v=LLrK-5J ... dex=3&t=0s
The video of calibration is unavailable?
If my offset is lower more than 5 points than offset from sticker what should i do?
marconazzi
Postby marconazzi » Mon Nov 04, 2019 1:54 pm
Even on Direto X you have to follow the same calibrations? and if you use it on erg mode but with Quarq PM, it is still needed?
daniele.testa1979
Postby daniele.testa1979 » Fri Nov 08, 2019 11:25 am
Hi, using Garmin 820, I have some questions:
1) How can I calibrate the Elite direto?
2) How can I define the circumference of the wheel?
3) Erg mode is an automatic function? If I set an interval 240 - 260 watt for 5 min., the direto keep this power?
flimps
Postby flimps » Wed Dec 04, 2019 11:09 pm
Mine shows a circumference of 2070 and is showing. 10-20 watts above what vercto 3, stages and 4iii show.
Any suggestion to have drivo 2 showing the correct power?
Return to “Direto”
