When I try to configure my new Elite Direto in My E-Training nothing happens, when I start pedalling. I am still able to calibrate it, but the app cannot find the power sensor serial?
Best regards
Peter
Elite Direto configuration
panoritaka@gmail.com
- 52269947_1557044357773752_7137621701851873280_n.jpg (63.64 KiB) Viewed 18649 times
- 51672223_1859972990781398_5240878047023857664_n.jpg (39.3 KiB) Viewed 18649 times
mook21@comcast.net
Re: Elite Direto configuration
I am having the exact same problem. I use my trainer with Zwift, but set up back in early 2018 with myetraining app to configure and it worked well on Zwift. I noticed everything seemed to get too easy to climb in Zwift... 9% gradient felt like 3 or 4 used to... so I went back in to configure on myetraining app. After trying, it would not set up power sensor just like shown here. I figured I would just go back and use Zwift and try again later and now there is almost no resistance even on 11% or higher gradients. I only changed trying to set up and configure again. HELP!! I need to at least get my Direto back to where it was before.
These data are only used for training within the My-E-Training app. The power meter is only populated if you have a separate power meter.
mook21@comcast.net wrote:too easy to climb in Zwift... 9% gradient felt like 3 or 4
Did you change the difficulty in Zwift to 100%: https://zwiftinsider.com/using-the-trai ... -in-zwift/
