Direto calibration question
PhilSJones
Postby PhilSJones » Tue Nov 13, 2018 11:10 pm
Just bought Direto. Offset on base says 6462. Calibration says 6459. Three lower.
I read elsewhere that a lower value might mean adjustment. What is the tolerance on this and are these figures OK?
elite
Re: Direto calibration question
Postby elite » Wed Nov 14, 2018 10:30 am
According Elite tolerance is maximum -5 points
Postby Elite Admin S » Fri Nov 16, 2018 12:59 pm
Not completely correct :geek:
The belt will always adapt a little to the trainer. And this means that the offset will decrease.
If the belt loosen much, not only the values decrease more than 5 points but also you should notice some issue (drop of power, slipping at high power, strange noise).
So, if you notice a drop in the offset value (more than 5 points) and also one of the issues above, then you have to tighten the belt (and in this case, please contact the customer care at myetraining@elite-it.com to have detailed instructions)
