Direto calibration
hmof
Direto calibration
Postby hmof » Tue Feb 20, 2018 11:03 pm
Hi, I just got my Direto. Does it need calibration? The instructions didn't mention it.
In the My Training app there is "Trainer Sensor Calibration". It tells me to start pedaling, but then nothing happens. When I go to ride in Dashboard -> Trainings -> Level mode, it sees the trainer OK, so the Bluetooth is working. I am using My Training on iPad.
Re: Direto calibration
Postby Elite Admin S » Thu Feb 22, 2018 12:19 pm
We suggest to do the calibration every 3-4 weeks of use.
In my e-training, if you do a normal training all works properly?
If it is so, but you cannot do the calibration still, please contact the customer care at real@elite-it.com to investigate further
hmof
Postby hmof » Tue Mar 20, 2018 9:11 am
Hi, today it worked in the My e-training app. I don't know what went wrong before.
I think the value was 6715. Is it good?
Postby Elite Admin S » Wed Mar 28, 2018 9:35 am
It depends on the original value of your trainer.
There's a sticker on the trainer with the original value, check it. If your value is close to that (not more than 5 points) it is ok.
If it is lower of more of 5 points, then it is necessary to tighten the belt (1 turn at time, then calibrate again and check if the value is ok, otherwise go on with another turn - NEVER exceed the original offset!)
hmof
Postby hmof » Tue Apr 10, 2018 5:35 am
Hi, where is the sticker? I don't see it.
Postby Elite Admin S » Wed Apr 11, 2018 8:38 am
It's on the bottom of the trainer.
eichenfield
Postby eichenfield » Sat Aug 25, 2018 5:24 am
I’m pretty sure my sticker says 6573, and my calibration returns 6508. I guess it’s possible it says 6513, but I doubt it. If it’s really off by 65, is there something wrong with the unit, or should I just tighten the belt. If so, how?
Postby Elite Admin S » Tue Aug 28, 2018 10:31 am
Contact the customer care at myetraining@elite-it.com specifying also the serial number of the trainer.
We have a register with all the original offset of the trainers, so we can check (and in case give you instructions on what to do)
Frans
Postby Frans » Thu Sep 27, 2018 11:25 am
Where exactly can I find the option 'Trainer Sensor Calibration' in the iOS app? It doesn't show up to me.
Postby Elite Admin S » Thu Sep 27, 2018 12:41 pm
The calibration wizard is in the Advanced Settings of the app.
The option appears only for the trainers that can be calibrated, of course.
