Direto XR Firmware v89
pierre.lepeer
Postby pierre.lepeer » Fri Sep 19, 2025 10:31 am
Upgrado just upgraded my Direto XR-T with the firmware v89.
I can't find any information about this firmware. What's new ?
Thanks !
steve.hammatt
Re: Direto XR Firmware v89
Postby steve.hammatt » Mon Sep 22, 2025 9:58 am
Interesting, thanks for the heads-up.
Hopefully it has some improvements for virtual shifting, given the feedback on the initial implementation in 87.
jdleff
Postby jdleff » Mon Sep 29, 2025 3:18 pm
I just updated to firmware 89 but the initial install failed. Support sent instructions which were simple and now it's accepted the new firmware. Don't update on a weekend if you plan to use your trainer!
Littlegrisu
Postby Littlegrisu » Thu Dec 25, 2025 6:20 pm
Hello jdleff,
I have the same issue with failing the update on my Direto and the Upgrado app.
It told me that it failed and that I have to restart the trainer again, but with this,
it does not show any light and does not connect to the app anymore.
What did the Elite support team told you today, to get it back running and to
do the update again.
Thanks for help...
Thomas
appjerezsur
Postby appjerezsur » Wed Dec 31, 2025 8:03 pm
buenas tardes
El firmware v89 para el Elite Direto XR (y XR-T) es una actualización importante que introduce mejoras, especialmente en la funcionalidad de cambio virtual y la experiencia general, aunque algunos usuarios experimentaron fallos iniciales en la instalación que requirieron soporte técnico o reconexión Bluetooth para resolver, resultando en una mejor integración de marchas y rendimiento en aplicaciones como Zwift.
Puntos Clave sobre el Firmware v89:
Mejoras en el Cambio Virtual: Permite un control más preciso de las marchas simuladas, acercando la experiencia a un cambio real, especialmente con el accesorio Click controller.
Compatibilidad: Funciona tanto para el Direto XR como para el XR-T.
Instalación: Algunos usuarios reportaron fallos iniciales; es crucial seguir las instrucciones de Elite y asegurarse de una conexión Bluetooth estable.
Problemas Comunes (y Soluciones):
Si la resistencia no cambia entre marchas, asegúrate de que la conexión Bluetooth esté activa para potencia y cadencia (no solo ANT+), como indica el foro oficial de Elite y publicaciones de Facebook.
Conectar el controlador Click no debe duplicar conexiones; se espera que se integre directamente.
Cómo Actualizar (General):
Usa la aplicación oficial de Elite (como MyETraining o una herramienta similar).
Asegúrate de que tu dispositivo (móvil o tablet) esté bien conectado al trainer.
Sigue las instrucciones, desconecta y reconecta si falla.
Si tienes problemas, revisa el foro oficial de Elite o contacta directamente con el soporte de Elite.
koteansuola
Postby koteansuola » Mon Mar 02, 2026 9:44 pm
Hi, have you experienced bad connection with garmin edge? I mean, trainer starts following a workout programmed in the gps, but few seconds later it gets hard, and does not follow the gps workout.
appjerezsur
Postby appjerezsur » Thu Mar 05, 2026 11:02 am
hola, no he tenido problemas a la hora de seguir entrenamientos progrados, tampoco he tenio problemas de desconexiones
Users browsing this forum: No registered users and 41 guests
