Elite Direto XR stopped working after failed upgrade
michal.postolski
Re: Elite Direto XR stopped working after failed upgrade
Postby michal.postolski » Mon Oct 13, 2025 3:22 pm
norbertw11k wrote:
michal.postolski wrote:Hello,
yes, the Elite guys helped me wonderfully !
It took exchanging 2 emails and they gave me working procedure and even a short movie how to fix the issue.
Everything was very clearly explained and the response very quick.
It turns out my doubts in customer service were absolutely unjustified - my apologies for that.
THANK YOU Francesco and Andrea!
HEJ.
Could you share this procedure here? It will definitely help many people. And it will speed things up ;)
IN MY CASE the procedure took 3 stepps:
1. install an app named "nRF Connect" on the phone and check if the app can "see" the device "DFU Targ" (in my case it could) and report back to Elite with results,
2. Upload a .zip file I recieved in next mail from Elite, (using the app) to the device (the email had a tutorial movie included - very simple).
3. After that I was able to use Upgrado normal way.
I suppose the file to upload is device-specific.
I suggest contacting with Elite and do exactly as they instruct. They responded to my ticket on the next day, and the day after the trainer was fixed.
Last edited by michal.postolski on Mon Oct 13, 2025 3:30 pm, edited 1 time in total.
sabastef
Postby sabastef » Mon Nov 17, 2025 11:20 am
same problem for me...
Ticket open to the Elite support but no answer for the moment.
It's a shame that a knwon problem isn't solved before deploying a new software version (it's not a 50€ trainer....)
david_endsor
Postby david_endsor » Wed Jan 14, 2026 7:55 am
Same for me. Failed part way through. Real shame as first impressions of the trainer were great but needed the upgrade for the zwift cog.
Did someone say it's more reliable to upgrade with upgrado on am apple device?
Raised a ticket with support and will see what that brings
