Firmware 87 rev 5
appjerezsur
Re: Firmware 87 rev 5
como comentente en el post anterior con otras versiones de bluetooth tenia algunos problemas de emparejamiento y funcionamiento, compre un BT5.4 de los que traen una pequeña antena, se pueden conectar hasta 5 dispositivos, de la marca UGREEN, 8 o 9 € , y desde entonces funciona perfectame, el emparejamiento es rapidisimo, y la transmision de los cambios tambien.
marroni.bruno
Dear All,
Sorry to bother you but I have some issues after downloading the new Firmware 87 on a Direto XR.
It seems that there is a problem of communication between my Garmin Edge 1030 and the trainer now. I explain, when i set up the slope or resistance on my Garmin, it works for more or less 20 seconds and then the resistance is increasing by itself...
I calibrated the trainer with my-etraining several times, I calibrated it with the garmin too, i tried to uninstall and to install again the trainer on my garmin, nothing changed...
Do someone have the same problem ?
Thank you for your help
Best regards,
Bruno
Best regards,
Bruno
marroni.bruno
Dear All,
Best regards,
Bruno
Best regards,
Bruno
pierre.lepeer
My main concern is an overall low resistance..
I have an updated Direto XR-T, with a Zwift Click.
As advised, I'm on the middle chainring at the front (3 chainrings) and on a sprocket that gives me good alignment at the rear.
When I start a Zwift session, the default gear is 8, and I ride like that for about ten seconds before starting to change gears.
My problem is that the overall resistance is lower than in conventional use. For example, on flat route, at 120W, i'm at gear 17 or 18. Even at speed 24, when sprinting standing, I'm still grinding away and hardly exceed 1,000 watts at RPMs over 140, whereas in conventional use, I'm at over 1,300 watts at 130 RPM.
An idea on how to increase the overall resistance ?
appjerezsur
hola pierre.lepeer, no se si has visto que coig tiene seis o siete posiciones para ajustar la linea de cadea, tal vez pueda ajustarlo en otra posicion con piñones mas pequeños, yo utilizo monopolato 32D y va perfeco.
guilhermecalheiro
marroni.bruno wrote: when i set up the slope or resistance on my Garmin, it works for more or less 20 seconds and then the resistance is increasing by itself...
I had this problem after updating as well.
Follow this instruction:
https://elitesrl.zendesk.com/hc/en-us/a ... e-trainers
Regards,
Guilherme
marroni.bruno
Than you very much. Problem solved
jacob.bp.93
Hi Pierre,
Did you find a sulution? I have the exact same issue. No resistance at all, except gear 24…
Jacob
Users browsing this forum: No registered users and 76 guests
