Hi, i have also recently started to get the squeaking sound on start up.
Can i ask where i find the ' Level 16 ' setting through the app ? Is it in Trainer setting ?
Squeak on startup
steve.hammatt
Re: Squeak on startup
I think you're probably referring to Level Mode in the MyEtraining app, where you can manually set the resistance. But I can't be sure without more context.
Users browsing this forum: No registered users and 46 guests
