Direto Firmware v88
Clayton5555555
Direto Firmware v88
Postby Clayton5555555 » Mon Jan 13, 2025 8:59 am
I've had my Direto for several years and have never had to perform a firmware update—until now, that is.
Using the Upgrado app, I have successfully updated to Firmware V88 Hardware Revision 11.
Does anybody actually know what's included with this update? After lots of searching, I can't find a Changelog or any indication of what's been updated.
steve.hammatt
Re: Direto Firmware v88
Postby steve.hammatt » Mon Jan 13, 2025 9:39 am
It's the virtual shifting support for Zwift.
Clayton5555555
Postby Clayton5555555 » Mon Jan 13, 2025 9:52 am
Thank you - I was hoping that may be the case.
It may be the time to invest in the 'Cog and Click' Upgrade.
Clayton5555555
Postby Clayton5555555 » Tue Jan 14, 2025 6:04 pm
Just received the Zwift Cog and Click. But unfortunately can’t get Zwift to find it. I can pair it in the companion app. So I’m guessing the click is working and it’s just a case of my direto not being compatible despite the latest firmware :(
steve.hammatt
Postby steve.hammatt » Wed Jan 15, 2025 9:06 am
You mean Zwift can't find the trainer? Because the Cog itself isn't something that you pair.
Maie sure you are pairing the trainer over Bluetooth (virtual shifting won't work over ANT+) and that the trainer is on the latest firmware.
Is your trainer a Direto XR?
Clayton5555555
Postby Clayton5555555 » Wed Jan 15, 2025 10:15 am
Hi Steve,
Zwift finds my trainer with no problem, it's just not recognising the 'Click' when I search under controls. I only use Bluetooth for my connections.
It looks like the problem is that I only have an early version of the Direto and not the XR. I guess I'm going to have to wait a little longer.
steve.hammatt
Postby steve.hammatt » Thu Jan 16, 2025 9:27 am
Yes, that's the problem then. Zwift won't pair the Click unless it can see a trainer that supports virtual shifting.
In this article from Elite, they say that virtual shifting is coming for several other trainers, including the Direto, in Spring 2025 (northern hemisphere since Elite are in Italy)
https://www.elite-it.com/en/news/direto ... g-on-zwift
jotaf.htc
Postby jotaf.htc » Fri Jan 17, 2025 12:54 pm
Hi guys, I am planning to buy the Zwift Ride (frame) to use it with my Direto XR-T.
I ahve updated the trainer to the new version of the firmware V88.
Has anyone faced any issues regarding compatibility or connecting the trainer to the zwift app?
Thank you
domin26-77
Postby domin26-77 » Fri Feb 07, 2025 12:44 pm
Tez miałem wersję oprogramowania 66 i działało poprawnie na Zwift, pozniej przesiadłem sie na My Whoosh, dalej ta wersja 66 oprogramowania działała poprawnie. Ale przyszło mi do głowy zainstalowac własnie wersję 88 i okazuj sie ze na My Whoosh ciagle występuje u mnie dryft mocy, na płaskiej trasie przy jednolitym kręceniu powiedzmy 100W, nagle musze kręcić do 200 W, to dzieje sie automatycznie ,dodam ze wcześniej nie przyspieszam. To dzieje sie co kilka minut. Nie wiem czy ktos spotkał sie z takim tematem w tej konfiguracji (Ditero X Oprogramowanie 88 i aplikacja My Whoosh w obecnej aktualnej wersji 3.9.3)
lunadam
Postby lunadam » Mon May 12, 2025 4:27 am
@jotaf.htc I’ve also updated to firmware v88 for my Direto XR-T and haven’t had major issues with Zwift pairing, but I did notice some inconsistencies in power readings—especially in apps like MyWhoosh, similar to what @domin26-77 described.
For Zwift specifically, everything pairs fine over Bluetooth, but make sure your trainer is fully recognized as a subway surfers "virtual shifting-compatible" unit. Zwift won’t detect the Click if it doesn’t see a compatible firmware/trainer combo (as @steve.hammatt pointed out).
If you’re running into issues with other apps showing odd wattage behavior (like drifting or sudden power jumps), it might be worth reaching out to Elite support or trying to revert to a previous firmware if you rely on multiple platforms.
Users browsing this forum: Baidu [Spider] and 34 guests
