My direto stopped changing resistance as a result of changes in the slope.
I just paired the direto to zwift on my macbook mini and my iPhone and to FulGaz on my iPhone and my iPad. Regardless the configuration, the Direto resistance remains constant no matter what the slope on zwift or FulGaz is. Absolutely no change. However, when doing training on zwift using ERG mode the resistance changes properly to match and maintain the watts. ometv chatroulette Therefore, is seems to be a problem with the command the unit is receiving when the slope is changing.
thanks
iosman
Direto resistance doesn't change with slope?.
Re: Direto resistance doesn't change with slope?.
Have the same problem on DiretoX- any solution?
Same issue with Zwift! Someone can help me?
marek.zelek
Yes, I have the same after upgrading to the latest version of firmware. Initially I thought it was the Zwift issue, but I tried the Elite app and the resistance remains flat when I adjust it on the app. Defo a trainer issue, either firmware or mechanical... I hope this can be fixed!
steve.hammatt
If the trainer resistance does not change when you use Level Mode in the myEtraining app and manually change resistance there, then you need to raise a ticket with Elite support - https://support.elite-it.com/en/ticket
Users browsing this forum: No registered users and 80 guests
