Calibration not succesful
stefan_l_01
Postby stefan_l_01 » Mon Nov 06, 2023 10:28 am
Win11 myEtraining latest update
V80 firmware
Tried to calibrate but when wheel stopped the app continued waiting for end, showing message box where i could abort. Happened with bluetooth and ant+ (in the past bt worked at least)
With android myetraining app it worked.
I had the feeling that I reached the 3x km/h to stop pedaling way earlier on the win app than in Android, if it helps
Stefan
Re: Calibration not succesful
Postby Elite Admin S » Mon Nov 06, 2023 11:50 am
please contact the support, it may be necessary to check the log file:
stefan_l_01
Postby stefan_l_01 » Mon Nov 06, 2023 9:04 pm
No sry. When ant+ did not work in the past I contacted support and it did lead nowhere. Now situation got worse.
I think someone of you (elite) has a win11 based laptop so install your stuff and test it yourself please. Maybe next time before release...
Postby Elite Admin S » Tue Nov 07, 2023 11:52 am
I understand your frustration and I appreciate your feedback.
Please write to the support again.
Our team is currently hard at work on a new update, and your valuable input, along with your data, could greatly assist in getting the problem sorted out swiftly. Thanks for being a part of our community!
AndyJ
Postby AndyJ » Wed Nov 15, 2023 11:16 pm
I only want to confirm this bug. I'm also on Windows 11 and either some update of My E-Training or some firmware update for the Direto XR broke something. The log file doesn't give much inside into the issue, I'm afraid. I'll post the end of the calibration log:
[15.11.23 19:57:25 - INFO]: [CalibrationManager] speed: 32,57162, targetSpeed: 33
[15.11.23 19:57:26 - INFO]: [CalibrationManager] Speed OK
[15.11.23 19:57:51 - INFO]: [CalibrationManager] Done
[15.11.23 19:57:51 - INFO]: [CalibrationManager] Response timer reset
[15.11.23 19:57:51 - INFO]: [CalibrationManager] Timeout timer reset
[15.11.23 19:58:02 - INFO]: [CalibrationManager] Calibration cancelled
[15.11.23 19:58:02 - INFO]: [CalibrationManager] Timeout timer reset
I wanted to test this on Android, but couldn't get a connection to my Direto. Next time I practice, I'll try to completely re-pair the Direto to my Android and try the calibration. I'll report back here with the result, but that won't change anything about the issue with the software on Windows 11, of course.
florencepugh
Postby florencepugh » Fri Jan 05, 2024 8:38 am
You should close the myEtraining app on your computer and then relaunch it. build now gg
hacksau
Postby hacksau » Fri Jan 05, 2024 5:01 pm
What works for me is to pedal longer/faster than the message tells you to. I have found if I get it going really good then stop pedaling it works. I think the message may pop up too soon- before the needed speed is reached.
Hope it works for you. Mark
timothyferriss
Postby timothyferriss » Thu Jan 18, 2024 10:05 am
Ensure that your computer's Bluetooth and ANT+ drivers are up to date. Outdated drivers can sometimes cause communication issues with devices. retro bowl
tonyadams
Postby tonyadams » Tue Jan 30, 2024 2:46 am
I hope the developers will release a fix or update soon to ensure a consistent and reliable performance across platforms. Fingers crossed for a resolution in the next update. Buckshot Roulette
farare
Postby farare » Fri Feb 02, 2024 9:28 am
Power-ups are strategically placed to enhance the gameplay experience. These dynamic boosts can include temporary invincibility, speed boosts, or even shortcuts that propel players ahead of the competition. Snow Rider
