Pedaling Analysis Direto
alwyn.jones
Postby alwyn.jones » Sat Nov 04, 2017 7:53 am
I have purchased the pedaling analysis extension. Do I need anything extra for the pedaling analysis to work for the Direto. E.g. External cadence sensor ? Will my Garmin cadence sensor do? Do I need an elite cadence sensor ?
Or should it work by simply connecting to the Direto without any additional sensors ?
I can connect to the Direto fine from app and desktop just the pedaling analysis won't work properly.
Re: Pedaling Analysis Direto
Postby Elite Admin S » Thu Nov 09, 2017 12:35 pm
You shouldn't have any problem without the cadence sensor (it will help to have a more precise result, but it is not necessary).
The only problem that there could be, is that the software won't be capable to understand which pedal stroke is the right/left one.
Can you tell me which problems did you experience with it?
alwyn.jones
Postby alwyn.jones » Fri Nov 10, 2017 7:38 am
That's the problem it didn't seem to show L and R just one line.
Please see attached photos
Postby Elite Admin S » Thu Nov 23, 2017 10:38 am
Are you sure to have a updated version of the app?
Are you sure to have selected Direto in the configuration?
Users browsing this forum: No registered users and 78 guests
