Direto XR Firmware 78 - 20% max incline reported
danjrod
Postby danjrod » Sat Jan 28, 2023 11:45 pm
The website says 24% (https://www.elite-it.com/en/products/ho ... ireto-xr-t), but reading the Supported Resistance Level Range over BLE the reported values are:
Code: Select all
[FTMS] Reading Resistance Level Range
Read Characteristic 002A : bytearray(b'\x00\x00\xc8\x00\x01\x00')
[FTMS][RLR] {'min_inclination': '0.0', 'max_inclination': '20.0', 'min_increment': '0.1'}
Can one still ask for 24% over the Fitness Machine Control Point "Set Target Inclination" op?
Or over the op "Set Indoor Bike Simulation Parameters"?
danjrod
Re: Direto XR Firmware 78 - 20% max incline reported
Postby danjrod » Sun Jan 29, 2023 2:07 pm
Please disregard the question. The value which was read is the "Resistance Level" which is not the "Inclination", for which the support bit is not set. I guess a "Rizer" element will have the "inclination" support.
The 24% inclination goes obviously directly into the "Set Simulation Parameters" FMCP call.
Best regards
Users browsing this forum: Bing [Bot] and 25 guests
